Einzelzündspulen widerstand
sjoeblom
Beitrag von sjoeblom »
Hello
I hope it's ok to ask in english, because my german is not sufficient this time.
I have bought a set of ignition coils from a honda that fits quite well into my zxr750J.
My concern is wether the resistance in the coils are to high or its ok.
Each coil has a resistance of 1.6 which adds up to 3.2 for the set, I think originally it is 2.8 ??
Will this be to much for my CDI or is it ok ??
You can answer in german, I read it well :D
Walnussbaer
Re: Einzelzündspulen widerstand
Beitrag von Walnussbaer »
Due to the fact that you are putting two coils in a row and that the voltage is bisecting to 6V it works out just fine with the resistance. Don't worry.
sjoeblom
thank you - I'll try it out then
