Greetings from the UK: My H2 work in progress
Verfasst: 28 Okt 2007 16:38
Greetings from the UK....
I thought I would post some pics of my H2 that I am converting to naked/fightering...
I have plans to swap the radiator with a larger one from the ZX6, mainly to do away with the thermostat etc...
I would also like to change the seat unit at some point, but I am looking for a seat unit that will bolt directly onto the current subframe with minimal modifications...
See what you think, Any comments/advice/sugesstions welcome!
Thanx,
Bleep
Verfasst: 28 Okt 2007 21:54
von Schabo
first of all: welcome at the zxr-forum.... :welcome: :welcome: :welcome:
as i can see, you´re on the right way with your zxr.... :wink:
i´d put the waterbottle near to the radiator. that would look much better.
i don´t think that you´ll find a seat unit wich you can bolt directly onto the current subframe with minimal modifications... :(
you have to build a new one.
Verfasst: 28 Okt 2007 22:21
HI
thanks for the reply!
I put the water bottle there as there is already abracket for it off the frame. I will be roving it toally when I fit the ZX6 radiator...Although I am not sure what to do with the piupe that comes off the bottom of the thermostat?
Thanx,
Bleep
Verfasst: 29 Okt 2007 10:04
von Schabo
i´d remove the complete thermostate and fit it under the tank.
Verfasst: 03 Nov 2007 17:56
Right
I have fitted the ZX6 radiator to my H2. But I do not know what to do with the pipe that comes out of the bottom of the thermostat? Where shoulc I connect it to? or can I simply remove it?
Thanx,
bleep
