heckhöherlegung H1
heckhöherlegung H1
Habe mir eine Höherlegung bestellt und als sie heute angekommen ist auch gleich voller Freude eingebaut... so weit so gut oder doch nicht....
habe dann festgestellt dass sich die hebel nicht einbauen lassen weil sie zu kurz sind... --> 140mm mitte mitte (ungefähr 1cm kürzer als die originalen Streben)
Hab ich da irgwendwas falsch gemacht (keine ahnung federbein zuerst ausbauen, auspuff abschrauben,...?) oder sind sie wirklich zu kurz?
mir ist es so vorgekommen als würde das federbein hinten an der schwinge anstehen...
lg
Wolfgang
lg
Wolfgang
Hi there!hagenf hat geschrieben:ich würde gern mal wissen wie lang die originalen sind, und wie lang die für die höherlegung sind
I'm new here and my german is a little rusty, so I hope English is OK for now. I'm from Sweden but I studied German in school some years ago.
I have hightened the rear of my ZXR H1 the way you are describing. The length of the original "hebel" (?) were about 155 mm (centre-centre), so I made new ones with about 147 mm. This turned out good on my bike and I wouldn't recommend hightening it very much more because the chain already rubs against the rubber chainguard on top of swingarm quite a lot, and this would get worse with more hightening. A few more millimeters might be OK though.
Hi pacman,
thanks for your posting. The Problem with the rubber and in the other hand problems with the Grip is also what we point out if we are asked about rear hightening.
Your posts are also welcome in english. If you have questions: No problem. The answers will be there also in english
Have a lot of fun with your bike!
There seems to be quite a lot of ZXR's running in Germany, so my guess is that there is also a lot of knowledge. Answers in English would be great, but I can also understand written German pretty good. Writing it myself is a totally different story though.Klaus69 hat geschrieben:Hi pacman,
Hagenf, I'd also like to know what length of the highteners that the tuning stores sell. Maybe I should try a different length also.
Hi Pacman,
i think language won`t be a problem. This Forum is the largest Meetingpoint of ZXR-Freaks in Germany.
Also the Community has a lot of knowledge about all kind of Motocycles and cars.
