Apologies if this is in the wrong section...
Now, I have fitted wide bars and risers to my H2..
But the throttle return cable is too tight and does not work; you have to manually twist the throttle close.
Does anyone have any reccomendations as to which other throttle return cable I could use?
Thanks
