not enought horse power?? just 115 hp from a zx9 egine
Hi
I have a zxr750 with a 900 engine build in.
I had it tested and it only makes about 115 hp on the wheel.
does anyone have some ideas what I can check.
it still has the 750 carburetor on it. can it be that? can I solve the problem by getting the 900 engine carburetor??
or can the problem be somewhere else?
I had the co2 testet and checked and adjusted the fuel/air.
hope you can help.
Best regards Esben, denmark
Which kind of ZXR do you own? J or L or whatever?
holie
Re: not enought horse power?? just 115 hp from a zx9 egine
Beitrag von holie »
EsbenBoll hat geschrieben:...
it still has the 750 carburetor on it. can it be that? ...
Hi EsbanBoll,
are that carburetor whithout restrictors? how many horsepower did the 750 engine had? 98, 100, 117...? And as Klaus asked which kind of Bike do you have? J,K,L,M,...
regards Holger
not enought
its a 1994 model.. thats an L model as far as I remember.
I dont think the carbs are restricted..
i just got the and with the 900cc engine in.
så I dont know enything about the 750 engine.
Kai
Admin a.D.
ZXR-Modellreihe: ZXR 900
Beitrag von Kai »
maybe your chain is very old?
there should be about 135 - 140 hp at the clutch... with about 25 % lost to the wheel...
25% Verlust von was? Von 135 PS an der Kupplung und dann zum Hinterrad?
Je nach Zustand eines Motors und der Kette, gehen zwischen Kurbelwelle und Hinterrad 8-12 PS verloren.
Kai
Admin a.D.
Beitrag von Kai »
Terrini hat geschrieben:25% Verlust von was? Von 135 PS an der Kupplung und dann zum Hinterrad?
haben diverse diagramme so belegt. aber wenn ich mir so manche ketten und radlager ansehe, wundert mich das nicht. ;)
ZXR L 93
Beitrag von ZXR L 93 »
Kai hat geschrieben:maybe your chain is very old?
If that is right, 115hp on wheel is very good,.....,everything fine :)
